mikegear
Feb 14, 2018Aspirant
ReadyNAS 4200 Corrupt Root Error
I recently got a used ReadyNas 4200. I put in 5 1TB disks into it and RAIDar shows "Corrupt Root". I have tried Factory Default option as well as OS reinstall but so far no luck. Four out of Five...
mikegear
Thanks for the response. I download firmware from Netgear website and compared with what was there on the internal flash drive, just visual comparison like filenames, folder structure etc and it looked very different. I will try zeroing on Windows PC and try again.
Btw can you provide some details on where does the device boot from? I read different places including disk, internal flash memory, internal read only memory etc.
Also let me if know factory default will reinstall os
mdgm-ntgr
Feb 14, 2018NETGEAR Employee Retired
There shouldn't be any folders on the internal flash, just some files. These are mostly files contained in the firmware image, but also the bootloader and the EEPROM data.
The NAS boots off the internal flash for the early part of the boot process then transfers to booting off the disks.
A factory default (wipes all data, settings, everything). It wipes the disks, setups the RAID, installs the OS and creates a new data volume. Think of it as if you got the unit from the factory like that except with the firmware on the flash that's currently on it.
- mikegearFeb 14, 2018AspirantThank you, the internal flash clearly has some folders so looks like thats not right. Where can I get new image for internal flash?
- mdgm-ntgrFeb 14, 2018NETGEAR Employee Retired
You could try USB Boot Recovery
However there is a side effect of this that the EEPROM data could be corrupted.
What's the downside on corrupting EPROM data? what does it contain, and is there a way to get the image without taking the risk of corrupting EPROM?
You can see current contents of flash drive here:
https://drive.google.com/open?id=1UfyJa51r-wlOb38C8B4XNhhftPhy38EF
can you please check and confirm what are these if not the correct image?
thanks in advance
