elippy24
Oct 06, 2024Aspirant
ReadyNAS 426- upgrading storage
I had 5 2TB and then I added 1 4TB drive and I didn't gain any storage but a new data -1 appeared. I have since added 5 more 4 TB drives and let the NAS resync between each drive that I have added. ...
Oct 07, 2024Guru - Experienced User
You should have stopped there.
Do you have a backup of the files on the NAS?
I suggest downloading the full log zip file from the logs page. If you need help analyzing the logs, you can
- upload the full zip into cloud storage
- PM me a link to the zip using the envelope icon in the upper right of the forum page
Make sure the permissions allow anyone with the link to download.
Don't post the link publically, as there is some privacy leakage when you do that.
