NGF
Oct 23, 2017Aspirant
ReadyNAS 42600 encrypted volume problems
1. after bootup nas shows timer 10 min, after that again and again i insert usb_with_key after 12+ hours and it start normally, for what this timer ? i need, i think for shutdown w/o key. 2. i need ...
NGF
big thanks for answer and again:
1. the timer is looped, i insert key after 12 hours and NAS showed Volume normally.
Question: for what that timer ?
2. i said about second key, what can erase pairs of key (nas-external key), to stop allowing read data with standard(default key). key for "3-rd" party people that can insert usb without me. they didn't get access and permanently block all data.
Question: in next firmware can you add checkbox to allow boot without external key. Add function to create "erase key".
3. all apps what i try to install didn't work properly(plex, resilio). resilio when i try to create share folder shows what cant access to *data*. try to read *data* volume what can be accessed only when i create x-raid volume. with flex-raid i have raid "volume_name_set_by_myself" (some apps cant write to it as i understand because try to search *data* volume!?).
Question: i can't see any apps in my web gui for 426, in what problem maybe?
Sandshark
Oct 23, 2017Sensei
Yes, the loop re-starts so you can insert the key whenever you are able.
Once a volume is encrypted, there is no turning back except to backup, re-format, and restore. A "boot unencrypted" option is not possible nor prudent where encryption is desired. The data itself is encrypted, it's not some add-on process. I don't work for Netgear, but I can tell you it just won't happen that they allow you to store the key on the NAS itself (which would be the only way to avoid inserting the key) because that would leave open the possibility of recovering that key even if erased.
As I said, it appears you encrypted your volume without really realizing the purpose and consequences thereof. The main purposes of it are that if your NAS is stolen, the thief will not have access to your data (unless you also leave him the USB key) and that you can safely discard a failed drive wihout some garbage picker being able to recover your data. It has nothing at all to do with security of the data in transit or someone accessing it once booted with the key (whether authorized or hacked).
Since creating an encrypted volume normally includes destroying the original data volume, I assume you did that but did not call the encrypted volume data. That can be problematic with some app installers, and it is a shame that Netgear does not warn about that.
What is the reason that you have encrypted your volume? I suspect you would be better off backing up your data, destroying and re-creating the volume unencrypted (calling it data) or even factory defaulting to a non-encrypted volume, and then restoring the data.
- StephenBOct 24, 2017Guru - Experienced User
I think that's an important question. Disk Encryption is only helpful if a thief doesn't get the usb key, so the key needs to be separately safeguarded. But it also needs to be accessible, since it needs to be reinserted on a reboot. If it's conveniently stored (or in the NAS), the thief might well steal it too. And of course, you need to keep another copy somewhere, since USB thumb drives fail.
As Sandshark says, disk encryption doesn't secure your data over the network - that depends on your password strength and configuration (including whether you require SMB encryption), and of course keeping your security patches are up to date.
On balance, I think the disk encryption has very limited value and isn't worth the risk of losing the key - so I've chosen not to use it.
