Fretting
Mar 22, 2017Aspirant
ReadyNAS 516 and Multiple EDA500 Expansion Chassis
I currently have a ReadyNAS 516 with all drive bays full and one EDA500 as a separate volume (e.g. data2). There are a total of (3) eSATA ports on the back. Can I run a total of (3) EDA500's, tha...
- Mar 22, 2017
Yes, you can. Note however that our new models don't support as many EDA500 units so if your RN516 died outside of warranty a suitable replacement NAS unit would only support one EDA500.
Fretting
Thank you kindly for the quick reply!
For the price, I'll take that chance. I have (3) other older ReadyNAS' and this will help me consolidate to the one platform.
Thanks again!
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
Sure. Just felt it was important to point that out. The performance of getting another main chassis e.g. RN316 (you'd connect that to your network via ethernet just like your RN516) would be a lot better than using an expansion chassis, but at the price you've been able to find the EDA500 at the EDA500 does provide quite good value.
Please also note that the warranty is for the original purchaser from an authorised reseller.
