Blues11
Sep 23, 2019Luminary
ReadyNAS 516 Best Practice
Two questions: First, I'm about to replace a disk (smaller disk with a bigger one). Is it best to shut down the box (to take out a 4TB drive and replace it with an 8TB) or can you simply do a hot sw...
Blues11
Sep 24, 2019Luminary
Hmm. I shut down the NAS and replaced the bad 4TB drive with the one I had taken out. On reboot it tells me that there is no volume. The four good drives are now colored red with the replaced 4TB drive in black.
Did I lose the entire volume?
- StephenBSep 24, 2019Guru - Experienced User
Not a good idea (and not what I suggested).
Blues11 wrote:Did I lose the entire volume?
Hopefully not. You could still potentially try what I suggested - putting the 4 TB drive you removed back in it's original slot. That is, put everything back the way it was before you hot-swapped in the 8 TB drive.
But If you do try that now, use the boot menu to boot up the volume read-only.
