DennisHomeUser
Aug 08, 2020Aspirant
Readynas 626x root partition keeps filling with snapshots
Hi, My readynas626x boot partition keeps filling with snapshots and locking me out. I have to ssh in and manually remove the snapshots in order to regain access to my system. How do I get the snap...
DennisHomeUser
Aug 15, 2020Aspirant
Thanks for your reply.
Hear is the directory with large backup files that i deleted. I have no backup jobs or Apps running on this readynas. I did set the snapshots to be pruned with the drive was 60% full.
/mnt/var/backups/shares
root@Revelstone:/mnt/var/backups/shares# ls -lhs
total 2.7G
508M -rw-r--r-- 1 root root 508M Aug 8 04:20 shares.tar
531M -rw-r--r-- 1 root root 531M Aug 6 04:21 shares.tar.0
423M -rw-r--r-- 1 root root 423M Aug 5 04:22 shares.tar.1.gz
423M -rw-r--r-- 1 root root 423M Aug 4 04:20 shares.tar.2.gz
402M -rw-r--r-- 1 root root 402M Aug 3 04:20 shares.tar.3.gz
397M -rw-r--r-- 1 root root 397M Aug 2 04:20 shares.tar.4.gz
root@Revelstone:/mnt/var/backups/shares# rm shares.tar.4.gz
Aug 15, 2020Guru - Experienced User
These are not snapshots.
I have the same files on my own system, but much smaller (~2.5 Mbytes total). They are backups of the ._shares folder on your data volume(s).
Can you poke around in ._shares, and see where all the space is going.
- Jun 06, 2017Retired_Member
