PGWARTH
Mar 10, 2020Aspirant
ReadyNAS and Google Home Router
I am unable to recover my password. Whenever I try is Recovery Failed. Is this a Netgear account issue or hadware issue. I'm using Google home router mesh system.
JohnCM_S
Mar 10, 2020NETGEAR Employee Retired
Hi PGWARTH,
Welcome to the Community!
Are you trying to recover the admin password of your ReadyNAS device? If yes, you can try doing an OS re-install. This will reset some settings on your NAS, such as Internet protocol settings and the administrator password, to defaults.
You may check this article for the steps on how to access the boot menu and select OS re-install.
PGWARTH
I re-installed the OS successfuly using your instructions.
However I am still unable to recover my Admin password and all attempts to remember my password have failed.
Whenever I fill out the Recover password page with my email address and the answer to my known security question, the recoevry fails.
- PGWARTHMar 10, 2020Aspirant
I also tried to use the default admin and password settings but that too did not work.
- PGWARTHMar 14, 2020Aspirant
When I try to log in using default Admin and Password, the log in credentials fail and takes me to a Password Recovery screen. When I enter my email address and answer the security question, it says the recover password fails.
- StephenBMar 14, 2020Guru - Experienced User
Are you navigating to https://nas-ip-address/admin
Then logging in as admin and password (both lower case)?
If so, I suggest trying this in an incognito/private browser window next.
- StephenBMar 11, 2020Guru - Experienced User
The OS reinstall resets the admin password to the default value.
If you have an RN100 series (or any other NAS running 6.x.x firmware), the default password is password.
