Sandshark
Apr 02, 2023Sensei
ReadyNAS BTRFS oddities
OK, so I'm messing with a new-to-me RN3220 and have found (or re-discovered in one case) some oddities in it's use of BTRFS. Most here will not understand or care, but with support from Netgear waning, I'm trying to understand as much as I can about how stuff works. Maybe somebody here is knowledgeable enough about BTRFS to help me.
The first thing, which I already knew, is that a multi-layer volume, even one created that way initially, not by vertical expansion, has no metadata assigned to anything but the first group. You have to run a balance to get that.
After completion of factory default volume sync with two drive sizes to force two groups, but before balance:
root@RN3220A:~# btrfs filesystem usage /data
Overall:
Device size: 6.36TiB
Device allocated: 138.02GiB
Device unallocated: 6.22TiB
Device missing: 0.00B
Used: 135.41GiB
Free (estimated): 6.22TiB (min: 3.11TiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 16.00MiB (used: 0.00B)
Data,single: Size:136.01GiB, Used:135.34GiB
/dev/md127 136.01GiB
Metadata,DUP: Size:1.00GiB, Used:36.75MiB
/dev/md127 2.00GiB
System,DUP: Size:8.00MiB, Used:32.00KiB
/dev/md127 16.00MiB
Unallocated:
/dev/md126 931.38GiB
/dev/md127 5.31TiB
After balance:
Overall:
Device allocated: 140.09GiB
Used: 135.41GiB
Data ratio: 1.00
Metadata,RAID1: Size:1.00GiB, Used:576.00KiB
/dev/md126 1.00GiB
/dev/md127 1.00GiB
Metadata,DUP: Size:1.00GiB, Used:36.25MiB
/dev/md127 2.00GiB
System,RAID1: Size:32.00MiB, Used:32.00KiB
/dev/md126 32.00MiB
/dev/md127 32.00MiB
System,DUP: Size:8.00MiB, Used:0.00B
/dev/md127 16.00MiB
Unallocated:
/dev/md126 930.35GiB
/dev/md127 5.31TiBNote that Data,single is because ReadyNAS uses MDADM RAID, not BTRFS RAID, so it's a single BTRFS volume. md126 simply doesn't show any use yet because there is so little on the NAS. But the System and Metadata are now shown on both md126 and md127. Lesson learned: Always do a balance after a vertical expansion.
But what's really odd is that it shows both RAID and DUP Metadata and System on md127. My other NAS of similar size and also using XRAID (RN4200V2 converted to OS6) are inconsistent. One has only RAID for both while the other has both RAID and DUP for metadata for one group by only RAID for system. Both of those units have been vertically expanded with less than the full complement of drives upsized, so that's not the difference. My main RD5200 converted to OS6 has been manually partly vertically expanded while in FlexRAID (per procedure documented in another thread), so everything on it is as I have set them: Metadata and System as RAID only.
I did a btrfs balance start -mconvert=raid1 /data and it cleaned things up:
Overall:
Device allocated: 140.13GiB
Used: 135.41GiB
Data ratio: 1.00
Metadata,RAID1: Size:2.00GiB, Used:36.78MiB
/dev/md126 2.00GiB
/dev/md127 2.00GiB
System,RAID1: Size:64.00MiB, Used:32.00KiB
/dev/md126 64.00MiB
/dev/md127 64.00MiB
Unallocated:
/dev/md126 929.31GiB
/dev/md127 5.31TiB
But what's going on with the default condition, and does it have any impact to performance and/or volume reliability/recoverability?
