sylvainp
Nov 11, 2019Aspirant
ReadyNAS DLNA - OS6
Hi all, I recently bought a Auralic Altair G1 (streamer/DAC/preamp) and I have some issue with playing DSD files with the Auralic. The Auralic can play DSD files. I have a Share folder for music wit...
sylvainp
Nov 15, 2019Aspirant
Yes, when I go with the PC I can see the .dsf files and I can also play them on the PC using Foorbar with DSD plugin.
The auralic see the DSD folders but not the .dsf files contains in the folders.
it's strange on the PC I see the files and not with the Auralic. Maybe it has something to do with the DLNA version in the OS 6.
Nov 16, 2019Guru - Experienced User
Yes - as I said earlier, the built in DLNA (minidlna) doesn't support that format.
I think you need to install a lightning server on the PC that is set up to access the NAS media shares, and use that instead of the NAS DLNA. Then the app would see it (when the PC is on). https://support.auralic.com/hc/en-us/categories/200358867-AURALiC-Lightning-Server
- sylvainpNov 16, 2019Aspirant
Yes, the Auralic Altair G1 as the built-in Lightning Server and when I try this I can play the DSD files.
Well, I have to use Lightning Server or I use Roon but the software is $$$
