MikaelNAS
Aug 03, 2025Follower
ReadyNAS Duo got stuck starting
Hello I have a ReadyNAS Duo has been working fine until yesterday when I was accessing it thru web interface (via Raidar 4.3.8), I got some warning messages due to Power failures in the house, but...
Aug 04, 2025Guru - Experienced User
MikaelNAS wrote:I know the unit is old, but I need the data on the discs.
1 - Any help to 1 get it working again, or if not possible,
2- how to move the data to new NAS
One option is to get R-linux for Window (free)
Then power down the NAS and connect disk 1 to the PC using a usb adapter or dock. Then see what R-linux finds.
If it doesn't find anything, then try switching to disk 2.
Once you get the data off, you can sort out how to get the NAS working again.
