claynz
Aug 19, 2022Guide
ReadyNAS Duo (RND2000 v2) Drive Access
Pulled this out of the cupboard and gave it a dust down and fully reset it, to find out I can not access it using Windows 10/11 due to limitations with web browser. how can I by pass it?
- Aug 19, 2022
You will have to use an older browser that supports TLS1.0 to access the admin page, IE11 or an older version of Firefox might help.
Are you having errors accessing data using file explorer? You may have to enable support for SMB1
Marc_V
Aug 19, 2022NETGEAR Employee Retired
