claynz
Aug 19, 2022Guide
ReadyNAS Duo (RND2000 v2) Drive Access
Pulled this out of the cupboard and gave it a dust down and fully reset it, to find out I can not access it using Windows 10/11 due to limitations with web browser. how can I by pass it?
- Aug 19, 2022
You will have to use an older browser that supports TLS1.0 to access the admin page, IE11 or an older version of Firefox might help.
Are you having errors accessing data using file explorer? You may have to enable support for SMB1
Aug 20, 2022Guru - Experienced User
claynz wrote:
Current firmware is 4.1.16 [1.00a043] is there a latest update available?
No, that is the final firmware for your Duo.
Note you can adjust the NAS to allow you to use http to connect to the admin page (turning off the redirection to https). That will let you use any browser. But the connection is not encrypted. More information on that is in this thread:
claynz
Aug 28, 2022Guide
Currently transferring 1.5TB of movie files around 1GB in size from my PC to NAS and only getting 15MB/s speeds, Is this normal for 1GB LAN?
- claynzAug 28, 2022Guide
No worries, I'll leave it transferring over night
What size drives does this unit support? I am currently running 2x2TB as single drives
- StephenBAug 28, 2022Guru - Experienced User
Just wanted to follow up on the sluggish transfer speed.
Many 2 TB drives are now SMR. These can have very slow write speeds - so you might want to confirm that you are using CMR drives.
Yes it's currently showing a C and a D volume in the web UI
Currently running
WDC WD2003FZEX-00SRLA0
Seagate ST2000DL003-9VT166 (Transferring data to at the moment)
RAID Level 0, Single disk
claynz wrote:
Currently running
I believe both of these are CMR - I'm not seeing much on the Seagate, but it is an old enough model (2011) that it should predate use of SMR.
Yes, it's old and not keeping it, transferring over Movies and TV Shows and sold it to a friend for US$185
