hardwire
Mar 02, 2023Tutor
ReadyNas duo v1 to Squeezebox Classic without a router?
I used to connect my Squeezebox Classic to my ReadyNas duo V1 via a home wifi network. I am now a user on someone else's wifi, so I'm hoping to connect them via ethernet without a router in between. ...
michaelkenward
Mar 03, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- StephenBMar 03, 2023Guru - Experienced User
I replied to your other post...
