jdemoccc
Mar 22, 2017Aspirant
ReadyNas Hard drive Serial Number
Does anyone know if there is anyway to determine the serial number of a hard drive inside a Netgear ReadyNas remotely? I am not onsite but i am trying to determine if the hard drive is still under wa...
- Mar 22, 2017
On the NV+ v1 go to Status > Health and look at the SMART stats for the disks. You'll see the disk serial numbers. You could alternatively download the logs and look in there.
Welcome to the Community!
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
- jdemocccMar 22, 2017Aspirant
Health only showed the model number but in the logs i found the serial number. thanks
- mdgm-ntgrMar 22, 2017NETGEAR Employee Retired
On the NV+ v1 there is a SMART+ button under Status > Health for each disk. Clicking on that would lead to a popular window opening showing the disk model, serial and SMART stats.
Thanks for the info, but i forgot to mention that the drive had failed and is currently missing so Smart+ is greyed out. But the logs helped.
