MInDev
Dec 06, 2020Aspirant
ReadyNAS NV+ blinking blue and green LEDs
My ReadyNAS NV+ has developed a fault. The blue power LED is flashing at inverals of about once per second, and one of the two HD LEDs is flashing at the same rate. I can ping the ReadyNAS, but I...
- Dec 07, 2020
MInDev wrote:
Assuming I go down this route and acquire another 1TB drive, is it best to leave the ReadyNAS powered on with the existing drive connected when I plug it in the new drive to begin the RAID creation process?
I do recommend doing a hot-insert (with the NAS running). The benefit of doing a hot-insert or a hot-swap is that the NAS detects exactly what is happening. If you do it with the NAS powered down, then it needs to figure out what changed.
Though doing it powered down generally does work too.
MInDev
Thank you very much for replying. My apologies, I should have clarified that the ReadyNAS has only two disks installed, both of 1TB capacity.
I also have an external drive connected to the ReadyNAS, and a nightly backup keeps the content synced.
I could try sourcing drive test tools for the disks. Currently I don't even remember what make and model they are.
Regarding booting from the drives, forgive my ignorance, but do you mean taking them out of the ReadyNAS and connecting them to my PC, and then booting from each drive from there? Or removing each drive in turn from the ReadyNAS, and then attempting to restart it?
I appreciate the note about SMR drives, I wish I'd done more research at the time, but perhaps I can make do with these ones. I'm not worried about performance, the ReadyNAS isn't used intensively. I just want it to be reliable.
Dec 06, 2020Guru - Experienced User
Removing each drive in turn from the ReadyNAS (powered down), anad then powering it up.
It's fine to keep the disks in there current slots (trying to boot up with disk 2 in slot 2, and slot 1 empty).
