blacksky's avatar
blacksky
ReadyNAS NV+ blinking power light
I have had the ReadyNas NV+ RND4000-100NAS since at least 2009. It has hummed along happily all this time without much issue. I did replace the power supply in 2017. My current issue: after booting it, the blue power light blinks, the disk lights are steady green, and the ip address is displayed on the green screen. I can ping that ip address without a problem. However, I cannot browse into the machine to see my files. RAIDar also does not find it anymore. I realize it is old(er), but what steps can I take to get the machine working again? Thank you!
  • StephenB's avatar
    Try powering down and removing all the disks (labeling by slot).  Then power up, and see if RAIDar can discover the NAS and report the
    "no disks" status.
    • blacksky's avatar
      blacksky
      Thank you for the reply! I powered down, removed the disks, powered up, and my Raidar detects the ReadyNAS now and reports 'no disks'
      • StephenB's avatar
        Ok.  Do you have a backup of the data?
ProSupport for Business
