JGumley
Dec 22, 2010Follower
ReadyNas NV+ Hitachi 3TB Drives.
I just purchased a ReadyNAS NV + 4 Bay, inserted 2 existing Hitachi 3TB Hard Drives (No Data on them) that I had in my old computer, powered everything on and now the Hard Drives read as 768Gb in size each. Any ideas on how I get them to be recognised as 3TB or there abouts. I have been fiddling around with the setting (X-Raid, Flex-Raid etc.) for a few days but no dice. Your input will be met with praise.
- Retired_MemberJust got my ReadNAS Ultra 4...where do I find the 4.2.16 beta?
- CharlesLaCourAspirant
- JessKaufmanAspirantWell i finally got it all together. now have a readynas Ultra 4 with 4 x 3 Tb Hitachi drives for about 8.5 Tb storage with X-RAID protection (one drive can die and all data stays intact). Not bad.
To others: you have to do the firmware upgrade without a 3 Tb drive (which I could not seem to make happen) or with a drive < 2 Tb. If you use the 3 Tb drive initially, you will not ever realize the 3 Tb of space (ask me how i know that). Instead, I used a single 500 Gb drive, installed the firmware upgrades, then did a factory reset, powered down, removed the 500 Gb drive and stuck in a 3 Tb drive. After power up, the ReadyNAS will begin preparing the drive. Then you just add the other drives and they will get prepared one by one, in order, as each one is done. Then I transferred all my data over after the entire RAID was up and running. - zmalexAspirantJess:
Did you get the Deskstar or Ultrastar?
I would like to have 3GB too but already the Ultrastar 2GB version is more expensive then the 3GB Deskstar. Not to mention the 3GB Ultrastar. Phew.
Does anyone know if the Ultrastar are worth the extra money? - JessKaufmanAspirantI got the Hitachi's and everything is working fine. 8.5 Tb on my ReadyNAS Ultra 4 with 4 drives.
- zmalexAspirantYes. But which model did you get? Ultrastar or Deskstar? :)
- PapaBear1ApprenticeActually the model number would be most informative for others, after all there are several models now of Hitachi 3TB drives.
- JessKaufmanAspirantHitachi Deskstar 0S03086 3.5" Hard Drive - 3TB, SATA3 (6Gb/s), 7200 RPM, 64MB, 3.5"
They are $190 at Global Computer:
http://www.globalcomputer.com/applicati ... No=7152490 - JessKaufmanAspirantobviously get them as cheap as you can. Its just incredible how cheap these are. I think back to my first hard drive in the 80's ... 5 Mb for just $2000 (5-1/4" full height MFM). To think that I can now buy 4 Gb SD flash for about $8. And now they have just released the 256 Gb SDHX flash. Can't wait for the first 1 Tb flash. By then the 256 Gb will be $8.
