kegerdal
May 12, 2012Aspirant
ReadyNAS NV+ v2: urgently need rescan command for DLNA
Problem: when new folder created from Windows 7: First a folder called "New folder" is created which is subsequently renamed to what I write for the folder name. This results in the following (from t...
mdgm-ntgr
May 12, 2012NETGEAR Employee Retired
5.3.5 beta is available. I believe you can use this to do a rescan
