kegerdal
May 12, 2012Aspirant
ReadyNAS NV+ v2: urgently need rescan command for DLNA
Problem: when new folder created from Windows 7: First a folder called "New folder" is created which is subsequently renamed to what I write for the folder name. This results in the following (from t...
kegerdal
5.3.5-T28 has been installed.
I had some trouble seeing the new services panel at first - caused by cached pages in Internet Explorer.
I found the DLNA rescan function, and when clicking it, it pops up a dialog box with "Rescanning in progress" where I click OK to make the message go away.
It looks like it does not do anything! No more files show up in DLNA. There is no messages in the log regarding (re)scan.
Also the problem with folders created from Windows still exists (a folder with name "New folder" is created which subsequently is renamed to something else.
The log says that "New folder" not found - it does not detect that it has been renamed!
Please fix asap!
Please fix asap!
