kegerdal
May 12, 2012Aspirant
ReadyNAS NV+ v2: urgently need rescan command for DLNA
Problem: when new folder created from Windows 7: First a folder called "New folder" is created which is subsequently renamed to what I write for the folder name. This results in the following (from t...
kegerdal
Found the following:
... this add-on will remove the ReadyDLNA database and thus force the ReadyDLNA database to be rebuilt on the new version:
(link to http://rnasguide.com/wp-content/addons/arm/DLNAREBUILDDB_0.1-arm.bin)
- after a while the DLNA database was rebuilt and all my files showed up in DLNA.
Until the rescan is fixed, I think it will be necessary to do this add-on after adding new files for DLNA.
