tigerten
Jan 28, 2024Luminary
ReadyNAS OS 6.10.10 released
Link to download: https://www.netgear.com/support/product/readynas_os_6#download Release Note: https://kb.netgear.com/000065999/ReadyNAS-OS-6-Software-Version-6-10-10 Cleaned up a b...
good4y0u
Feb 06, 2024Star
It would be best at this point for Netgear to just release instructions on how to load your own OS on the hardware if you want as part of a "recyclable and reusable End Of Life and Support" plan or something.
- givememynamebakFeb 15, 2024Luminary
good4y0u wrote:It would be best at this point for Netgear to just release instructions on how to load your own OS on the hardware if you want as part of a "recyclable and reusable End Of Life and Support" plan or something.
good4y0u - Actually, It would be best for them to opensource all the code so the community can take over from where they have given up. It makes no sense for them to hoard the code as if they're going to resurrect it someday with something newer because it'd be far to stale by then.
