olest
Aug 13, 2013Guide
Readynas OS6 future requests
1)
Snapshot function on Home folders.
2)
Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots
3)
Option to start ReadySYNC client automatically for each NAS on Readynas Remote client
4)
Add an ignore, delete or quarantine file option to virus detections
Also see my buglist at http://www.readynas.com/forum/viewtopic.php?f=154&t=72312
2)
3)
4)
- ReadyASGuideSimply do the normal SMART report pages, please.
- fastfwdVirtuoso
mdgm wrote: If you have a Mac you can easily use two finger scroll on the trackpad. Not sure if there is an equivalent for Windows.
If your Windows laptop has a Synaptics touchpad, as most do, there's a control panel for activating all sorts of extra features, including two-finger scroll. - ReadyASGuide
StephenB wrote: mdgm wrote: [...]
Even if there is a way, the fact that the popup scrolls at all is not obvious. They should make this popup work like all their other scrolling windows. It needs to be easy to see the SMART stats.
The old GUI (OS4) is very good in my opinion and SMART report is presented very good without unnecessary bizarre efects.
I hope that simplicity and functionality will win with the pressure to do "modern" GUI at all costs. - StephenBGuru - Experienced User
Not sure either (particularly for Win7, which is what I am using).mdgm wrote: If you have a Mac you can easily use two finger scroll on the trackpad. Not sure if there is an equivalent for Windows.
Even if there is a way, the fact that the popup scrolls at all is not obvious. They should make this popup work like all their other scrolling windows. It needs to be easy to see the SMART stats. - mdgm-ntgrNETGEAR Employee RetiredIf you have a Mac you can easily use two finger scroll on the trackpad. Not sure if there is an equivalent for Windows.
- ReadyASGuideMy 5: there is no case with UPS. Thank you again StephenB!
viewtopic.php?f=10&t=74853 - ReadyASGuide
StephenB wrote: You can do (5) - my RN102 shares the same UPS as my NV+ and duo v1.[...]
So, should I try connect UPS to USB of my Ultra with OS6 and share for Pro and NV+?StephenB wrote: [...]On (2) If you have a mouse with a wheel, you can see most of the SMART stats from the UI (the SMART window scrolls). But if not, you do need to download the logs. I agree that is a pain.
Thank you! Yes it's a pain. For instance I can't do it on my laptop, I should connect the mouse.
In my opinion NTG should change it in newer versions - SMART parameters easily presented. - StephenBGuru - Experienced UserYou can do (5) - my RN102 shares the same UPS as my NV+ and duo v1.
On (2) If you have a mouse with a wheel, you can see most of the SMART stats from the UI (the SMART window scrolls). But if not, you do need to download the logs. I agree that is a pain. - ReadyASGuideI had the functions in OS4, but they are missing in OS6 - I need them back:
1. More than one email address field for alerting (is only in OS6 1 instead of 3 like in OS4).
2. More detailed SMART report (should be detailed as in OS4).
3. Possibility to schedule switch off the NAS only (in OS6 I should define on and off simultaneously, but I need only off).
4. Correct RAIDar status is needed - look at: viewtopic.php?f=7&t=73807
5. Possibility to connect to ReadyNas with OS4 for UPS status (I can link OS4 NAS with OS4 NAS, but no OS6 NAS with OS4 NAS connected to UPS). - mdgm-ntgrNETGEAR Employee Retired3. You can already shutdown/reboot the ReadyNAS from the web admin interface.
