bobofruit
Oct 22, 2020Tutor
ReadyNAS Pro 2 BIOS Update before migration to OS6
Hi, I have ReadyNAS Pro2 working on RAIDiator 4.2.31 . I am trying to find the latest BIOS to install it before upgrade of my readynas pro 2 to OS6 Currently my bios date is 09/08/2010 ...
- Oct 23, 2020
Install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Since you need a backup any to do the conversion, it's sensible to do this after you back up the NAS (but before you do the OS-6 conversion).
Oct 23, 2020Guru - Experienced User
I don't have a pro2. But looking at the install script in the add-on, it does appear to include the pro2 and ultra2.
bobofruit
Oct 23, 2020Tutor
Thank you for all your informations.
I did successful bios update according your instructions.
Now I have new bios with date 11/02/2011.
Now will upgrade to OS6
- bobofruitOct 24, 2020Tutor
All process went without any problem.
My RN PRO 2 works nice with OS6.
Thank You friends.
- StephenBOct 24, 2020Guru - Experienced User
Great!
One thing you might look into is upgrading the RAM in the NAS. The Pro2 shipped with 1 GB, comparable OS-6 systems now have 2 GB.
This is one option that should work: https://www.amazon.com/Crucial-CT25664BC1339-SDRAM-Memory-Module/dp/B004XMA6M8
I have 2GB of RAM installed.
Few minutes ago I have installed Logitech Media server 7.9.3 app from:
http://downloads.slimdevices.com/LogitechMediaServer_v7.9.3/logitechmediaserver_7.9.3_all.deb
LMS works very good. My logitech Transporter plays music. LMS page opens . Everything works, but LMS is not wisible as installed app.
Readynas shows "No installed apps".
Why?
