jonjon79
Feb 14, 2025Aspirant
ReadyNAS Pro 6 - issue w/ TLS 1
product - ReadyNAS Pro 6 not updated yet. I've read other posts & have tried installing & using TLS 1.0 browser (couple older Firefox, currently on 43.0.1), also tried 94.0.2. still unable to get the...
saudade
Feb 14, 2025Apprentice
Did you set "security.tls.version.min" to 1 (browse to about:config and search for the setting). This is for Firefox.
jonjon79
it was already set there by default:
min = 1; max = 3
- StephenBFeb 14, 2025Guru - Experienced User
min = 1; max = 3
What happens when you try to reach the page?
- jonjon79Feb 14, 2025Aspirant
after taking +/- 5 minutes or more to finally time out when trying to reach/load the page, the error says:
Secure Connection Failed.
the connection to 192.168.1.110 was interrupted while the page was loading.
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
- SandsharkFeb 14, 2025Sensei
That sounds like a different problem. Are you running any antivirus/firewall software?
