bla_1
Aug 06, 2020Aspirant
ReadyNAS Pro 6 CPU-fan Calibration button
INFORMATION: Netgear ReadyNAS Pro 6 Firmware: 4.2.31 X-Raid 2 Fan SYS 936 rtm Fan CPU 2156 rtm Temp SYS 45° Normal 0-65°C Recalibration OK Temp CPU 25.5°C Nor...
Sandshark
Aug 06, 2020Sensei
It's been a long time since I ran 4.2.x on a Pro6, but I don't remember two calibrate buttons. But one thing that may make a difference is whether your Pro uses a 4-pin fan connected next to the CPU or a three-pin one connected to the daughterboard. Or did you, perhaps, plug it into the wrong connector for your fan type?
Aug 06, 2020Guru - Experienced User
There's only one (on the sys fan). My CPU fan also always runs a bit over 2000 rpm.
- SandsharkAug 06, 2020Sensei
Of course, the thermal properties of the heatsink compound improve with age in the first few weeks, so things may change as time goes on. I only have one Pro6 still set up, and it's on OS6, but it's CPU fan runs in the 1600Hz range on the "Balanced" setting. When I had three NAS running side-by-side, they ran a little hotter, so the fans were a bit faster.
