bla_1
Aug 06, 2020Aspirant
ReadyNAS Pro 6 CPU-fan Calibration button
INFORMATION: Netgear ReadyNAS Pro 6 Firmware: 4.2.31 X-Raid 2 Fan SYS 936 rtm Fan CPU 2156 rtm Temp SYS 45° Normal 0-65°C Recalibration OK Temp CPU 25.5°C Nor...
Aug 06, 2020Guru - Experienced User
Sandshark wrote:
It's been a long time since I ran 4.2.x on a Pro6, but I don't remember two calibrate buttons.
There's only one (on the sys fan). My CPU fan also always runs a bit over 2000 rpm.
Sandshark
Aug 06, 2020Sensei
Of course, the thermal properties of the heatsink compound improve with age in the first few weeks, so things may change as time goes on. I only have one Pro6 still set up, and it's on OS6, but it's CPU fan runs in the 1600Hz range on the "Balanced" setting. When I had three NAS running side-by-side, they ran a little hotter, so the fans were a bit faster.
