bla_1
Aug 06, 2020Aspirant
ReadyNAS Pro 6 CPU-fan Calibration button
INFORMATION: Netgear ReadyNAS Pro 6 Firmware: 4.2.31 X-Raid 2 Fan SYS 936 rtm Fan CPU 2156 rtm Temp SYS 45° Normal 0-65°C Recalibration OK Temp CPU 25.5°C Nor...
Sandshark
Aug 06, 2020Sensei
It's been a long time since I ran 4.2.x on a Pro6, but I don't remember two calibrate buttons. But one thing that may make a difference is whether your Pro uses a 4-pin fan connected next to the CPU or a three-pin one connected to the daughterboard. Or did you, perhaps, plug it into the wrong connector for your fan type?
bla_1
Sandshark wrote:It's been a long time since I ran 4.2.x on a Pro6, but I don't remember two calibrate buttons. .
So the first question should be: is there any "Calibrate" button for the CPU-fan?
If yes, how can I get it back?
- bla_1Aug 06, 2020Aspirant
Sorry, I didn't see your answers. So there is just no Calibrate button for the CPU-fan.
Thanks for both of you, Sandshark and StephenB.for your answers.
