Flapinux
Jul 16, 2019Aspirant
ReadyNAS Pro 6 PSU replacement
The PSU finally failed on my ReadyNAS Pro 6 and I found a manuf/seller on ebay & decided to give it a shot (link below) My question is, does anyone have a pic of the correct jumper placement on th...
Flapinux
I'm fairly certain this is correct, anyone wanna double-check my work?
- SandsharkJul 16, 2019Sensei
See the diagram for C13/C14: IEC connector chart.
BTW, what brand and model of supply did that end up being? Did it need (or come with) an extender for the 24-pin connector? I've been looking for a recommendation of a replacement supply now that the orignal Seasonic has been discontinued. If the supply came with the extender and 3 4-pin MOLEX connectors, then maybe the price isn't too over-inflated for an SFF form factor supply.
- FlapinuxJul 16, 2019Aspirant
I'll let you know when I receive it
