kped
Dec 04, 2012Aspirant
ReadyNAS Pro (RNDP4410-100NAS)
I am getting ready to upgrade my memory on my NAS unit. I purchased the Corsair VS4GSDS800D2 4GB DDR2 My question is, how long does it take to run the memory test after install? This unit is use...
ReadySECURE
Dec 04, 2012Apprentice
Shouldn't take too long to run, perhaps anywhere between 1 hour to 4 hours. It should only do 1 pass of the memory test and then you would need to reboot the unit. It will sit and do passes until the end of time (or the memory sticks)
