rclark
Nov 01, 2012Tutor
ReadyNAS Pro (RNDP4xxx) Memory...
Anyone have any recommendations on compatible memory for a ReadyNAS Pro Series (RNDP4410)? I have a client that needs to upgrade the memory in their ReadyNAS to 4GB to accommodate a large number of...
rclark
Nov 02, 2012Tutor
Thank you, I've read & understood all that as well...
All I could find listed in the technical specs of the the hardware manual (http://www.downloads.netgear.com/files/ ... July11.pdf) for the RNDP4xxx is that it comes with 1 GB DDR2 SODIMM RAM. Anyone know what speed - 667 or 800? Does it matter? Any particular brands to stay away from?
Also, I've never had to take one of these apart - is the memory slot easily accessible? Any other potential "gotchas" I should be aware of?
TIA
-Randy
TIA
-Randy
