Pkcharlie's avatar
Pkcharlie
ReadyNas Pro unable to uncheck " Enable monitoring of UPS physically attached to a remote ReadyNAS"
okay - I must be losing it or getting tired or something, but for the life of me cannot find out how to uncheck the
"Enable monitoring of UPS physically attached to a remote ReadyNAs" or the " Monitor UPS over SNMP" on my RNDP6000.
Both check boxes are greyed out.  What am I missing?
    Looks like you can't uncheck them because you have no UPS connected to the NAS.
    • Pkcharlie's avatar
      Pkcharlie
      so you need to physically unplug the UPS to allow the the check boxes to be avaiblabe?  That sounds like a UI/UX design blunder but I'll give it a try.
      • StephenB's avatar
        Guru
        Other way around - you need to plug in the UPS.  Your screen shot shows that the UPS isn't connected.
