wilkster
Nov 08, 2020Aspirant
readynas ps4 plex setup
Greetings all, New to NAS and set ups etc. Im trying to set up a nas with plex running on a PS4. Can anyone point me to a previous descussion regarding this or help in any way. Just want plex to ...
Nov 08, 2020Guru - Experienced User
wilkster wrote:
Iv set the manual server on plex to IP of what i connect to nas on laptop(192.168.0.34) port 32400(default)
Plex has a library folder on PS4(nas is named Library)
Are you using the same account on the PS4 as you are on the NAS PMS server?
Try setting "Allow Fallback to Insecure Conections" to always on the PS4. On the NAS, make sure the network setting for "secure connection" is set to preferred, and the local network discovery (GDM) is enabled.
You could also make sure the DLNA server in plex is enabled, and then see if the PS4 media player can access your media using DLNA. (It's best to disable Netgear's built-in DLNA in your share settings if you do this)
wilkster
Nov 10, 2020Aspirant
Thank you stephen, that helped. problem seemed to be also having everything updated and old software on nas. appreciated the help.
