Pascal27
May 21, 2017Aspirant
ReadyNAS RN104 showing space used for snapshots when snapshots set to never
Hello I have the same problem as this closed topic : https://community.netgear.com/t5/New-to-ReadyNAS/ReadyNAS-312-showing-space-used-for-snapshots-when-snapshots-set/td-p/1063116 In the RN104, I ...
jak0lantash
May 27, 2017Mentor
Pascal27 wrote:
Thanks Stephen
Unfortunately, I am working with Mac....
Then it's even easier. Open a terminal and SSH...
mdgm-ntgr
May 28, 2017NETGEAR Employee Retired
Applications > Utilities > Terminal
# ssh [email protected]
Hit the enter/return key and you'll then get prompted to enter the password.
- Pascal27May 30, 2017Aspirant
Thanks, the "#" shall not be type in.
now I have a problem with password....I enter the readynas password but it isn't accepted. Very difficult !
- StephenBMay 30, 2017Guru - Experienced User
That password should be the NAS admin password.
Also, make sure "enable password authentication" is checked in the web ui (system->settings->ssh).
OK, thanks I will try tomorrow or day after : the NAS is presently updating to a new firmware (just hope ther will stay enough place to install..)
- Jun 06, 2017Retired_Member
