Pascal27
May 21, 2017Aspirant
ReadyNAS RN104 showing space used for snapshots when snapshots set to never
Hello I have the same problem as this closed topic : https://community.netgear.com/t5/New-to-ReadyNAS/ReadyNAS-312-showing-space-used-for-snapshots-when-snapshots-set/td-p/1063116 In the RN104, I ...
Pascal27
Jun 03, 2017Aspirant
Hi,
No answer = no solution ???
It's becoming critical : I retried the orders but this time, I've got that answer when typing "systemctl restart readynasd" :
"Failed to add /run/systemd/ask-password to directory watch: No space left on device"
Pascal27
Jun 23, 2017Aspirant
StephenB or mdgm-ntgr : would have an answer/solution to my problem ? I can't even do it again because to low space left....
- StephenBJun 23, 2017Guru - Experienced User
Yikes.
Do you have a backup of the data?
- Pascal27Jun 26, 2017Aspirant
Unfortunately, I don't have a backup of all data and it takes a lot of place and time :(
That's why I really would like to recover theses Go of snaphots....
- StephenBJun 26, 2017Guru - Experienced User
I'd suggest paid support then (my.netgear.com). You can ask for per-incident, which will give you an hour of support.
And I'd also suggest backing up what you can.
- Jun 06, 2017Retired_Member
