icecoldbaseball
May 22, 2020Aspirant
ReadyNas RN2120 Corrupt Root
Am looking for help to start my NAS again. I am in the stage where I already did a hard factory reset, with the pin at the front. Even that, when I boot, I get "corrupt root" message on RAIDar. Follo...
Sandshark
May 22, 2020Sensei
Just to be clear, you did a "Factory Default", not just an "OS Re-install"? You need to do the factory default to get back to square zero (which does man you lose all data, but I assume you know that), and it does not sound like that's what you have done. If that iis what you did, one of the drives may be bad.
Another option is to remove the drives and zero them (just removing all partitions is usually sufficient) using a PC, then power on with the "fresh" drives. Since you've apparently not used the NAS for a bit, using the manufacturer's tools to test the drives while you have them out could save you some head scratching and/or heartburn later, too.
- icecoldbaseballMay 22, 2020Aspirant
Yes I factory Defaulted it.
I can not even get in the GUI
I stuck a fresh drive in the Nas and RAIDar said installing and then corrupt root.
- StephenBMay 23, 2020Guru - Experienced User
Test the drives in the PC with vendor tools (lifeguard for western digital; seatools for seagate). I recommend running both the extended non-destructive test and a full write-zeros test.
If it's not the drives, then it could be a problem with the firmware image in the flash.
- icecoldbaseballMay 23, 2020Aspirant
Drives pass no issues.
If it's a problem with the firmware image in the flash. How can we fix that? I can telnet into device from two different tech support modes. One says debug Telnet and another says debug and some numbers.
