lfrye
Jul 19, 2019Aspirant
ReadyNAS RN3220 Volume is Degraded but all green lights & no errors on disks
Hello, I'll start by stating I do not know what this "*Select Location" thing is while creating this discussion, so I apoligize if I used the wrong "Location". Here is the issue: I have a Ne...
Jul 30, 2019Guru - Experienced User
lfrye wrote:
We replaced the drive but it is not rebuilding. How do I make it rebuild the disk? It currently says the state is healthy but has been stuck on "Balancing in progress 0% complete" since we replaced the drive 4 days ago.
Odd. Did you start the balance before you replaced the drive?
Can you download the log zip file and post mdstat.log (copy/paste it into a reply).
lfrye
Jul 30, 2019Aspirant
I was getting errors when trying to download the logs so management I told me to reboot the NAS. Just before it rebooted I received email notification saying the balancing had completed then the device rebooted. When it came back online 10 mins later all the drives were Blue and health was normal.
I really should have just rebooted the NAS before coming here, but I was kinda worried I would lose the array.
Thank you StephenB for your help!
- StephenBJul 31, 2019Guru - Experienced User
So the volume is rebuilt now?
You can confirm that by looking at mdstat.log in the log zip file.
