garch1
Oct 03, 2022Guide
Readynas RN516
Just a few days ago my psu in my loved RN516 is gone. Up to know I could not find any spare or similar psu just to test if something else in my unit is damaged. Over many years I used my RN516 almost...
Sandshark
Oct 07, 2022Sensei
My memory failed me. The 516 (and 316 & 716) do use Netgear's alternate pin-out for the ATX type connector on the power supply (/ReadyNAS_PSU_pinout.pdf). So in order to use a standard ATX supply externally to see if that fixes the problem, you'll need an adapter cable or to re-wire it slightly. Unlike the legacy units, however, the fan is still installed in these models' supplies.
garch1
Oct 12, 2022Guide
Thank you very much for sending me the psu wireing diagramm... helped.
It really seems that the old installed psu is dead on the +12V... so I did my test with a 20 pin ATX psu, either ways wired.. but no luck with that. Unit wont turn on... so I tried to avoid power button in front. No luck as well... It really seems
Finally, I kept thinking about getting a UPS. I don't know if this would have helped, but I'll use it in the future.
- joe_schmoOct 12, 2022Tutor
I haven't seen a Netgear ReadyNas for sale new in quite some time. I needed a new NAS recently and ended up going with a different brand.
- SandsharkOct 13, 2022Sensei
My "parts" 516 has essentially the same issue, caused by a short somewhere on the board that I can't find. I bought it that way, but really expected all it would need is a power supply. One thing you can look for (but I didn't find on mine) are any large electrolytic capacitors that are bulging.
Without a schematic, I just didn't think it was likely I could find the location of the short, so I didn't do a huge amount of troubleshooting. So I can't even give you any addition pointers on where to look if you are inclined to try and fix it.
