Gyttja
Dec 06, 2019Aspirant
Readynas RNDP 6000 with OS6 with crashed disk wont boot anymore, how to recover?
Hi, I have a readynas RNDP6000 / ReadyNas Pro 6 with 6 disks. A while ago I use the mothod found on this forum to upgrade it to OS6, worked like a charm. Now I have a disk that crashed and the...
Dec 06, 2019Guru - Experienced User
Gyttja wrote:
The thing is, it wont boot anymore, the screen just says readynas, and nothing happens. Not even if you keep it on for hours.
This actually sounds like a power supply failure to me. If the supply is only outputting 5 volts, then you will see this symptom.
Try powering down, and removing all the hard disks (labeling by slot). Then power up, and see if the system still does this, or if it boots and displays no disks on the LCD.
You can also try accessing the boot menu (which is done the same way it was before), and see if that responds.
The PSU can be replaced, Sandshark is a good resource on doing that.
Gyttja
Seems like you are right.
Disks out is same simptons, makes no difference at all.
I will try to figure out how to replace the powersupply.
