Gyttja
Dec 06, 2019Aspirant
Readynas RNDP 6000 with OS6 with crashed disk wont boot anymore, how to recover?
Hi, I have a readynas RNDP6000 / ReadyNas Pro 6 with 6 disks. A while ago I use the mothod found on this forum to upgrade it to OS6, worked like a charm. Now I have a disk that crashed and the...
Gyttja
Sandshark
Do you know it this one whould work? As I can only find the one you recomend for very high prices in europe.
https://www.megekko.nl/product/0/1735615/FSP-Fortron-FSP300-50GHS-85-300W-SFX-Wit-power-supply-unit?r=googleshopping&gclid=CjwKCAiAlajvBRB_EiwA4vAqiC42UNUD-czSgncPiuWg_-GCwh7LPAVYVUv9C7brYPS2EEthEzjS9xoCvGAQAvD_BwE
It is suggested in this tread:
Gyttja
Oh wait, is this the one I need?
https://azerty.nl/product/seasonic/3323326/ssp-300tbs-voeding-intern-tfx12v-2-3?utm_source=nl.hardware.info&utm_medium=cpc
Or this:
Or this one:
It states that the 20pin connecter has 35cm line lengt. Maybe I save on the 20pin extending cable than? Or do I still need that?
And I need to make one extra 4 pin connector, not a problem, I make it myself or maybe I still have some sata to 4pin converters laying aroung.
