LarryMoberly
Jan 24, 2021Aspirant
ReadyNAS to Mac SMB Connection
I just did a full MacOS Big Sur reinstall in my iMac and now my RN214 backups will not connect to the Mac. (Test connectionn to host fails or does nothing). The NAS sees my xxxx-iMac.local as a host ...
- Jan 27, 2021
Ended up being pretty straightforward. In MacOS Preferences/Sharing, the File Sharing must be clicked ON, and the shared folders to be backuped need to be listed with permissions for whatever user ID you are using.
What I missed was the Options button. Share files using SMB must be clicked on (which it is by default) [In Big Sur OS AFP is no longer an option; it is in older MacOS.] --->> Then in the Windows File sharing section I needed to click the account I'm using (then it asks you your password). That is what makes it work.
It becomes a little cloudy what is going on since that is the same user and password I supply for the NAS backup setup. It looks like the default Mac preference is trying to prevent another Windows server from storing and using your ID/password.
Anyway I am getting my backups going again using the NAS214 to remote access various Mac folders. (using the Windows time stamp method). Thanks for the replies and brain stimulation.
schumaku
Jan 26, 2021Guru - Experienced User
The NAS does -never- initiate and establish a connection e.g. by SMB back to the client, e.g. the Mac here.
Be aware the direct NAS<->Mac connection IPv4 addresses must be in a different subnet than used for the "normal" LAN as configured on the Mac and the NAS.
Assume you are using TimeMachine, I'm a little bit lost where and how you see a connection attempt from the NAS to the Mac...
