ChevaTomme
Apr 28, 2021Aspirant
ReadyNAS Ultra 2 - How to set start day in Backup Schedule?
Hi, How can i specify what day that will actually be considered as the start of a backup schedule? Manuals urge that backup settings are tested manually, but when satisfied with the settings ...
Apr 28, 2021Guru - Experienced User
ChevaTomme wrote:
Manuals urge that backup settings are tested manually, but when satisfied with the settings how can i specify what day that will actually considered as the start day of a schedule?
I set full backup at once a week but i want that at specific day and times, the rest will be incremental.
Is your NAS running 4.2.x firmware, or have you converted it to run OS-6?
With 4.2.x, per page 93 of the manual
https://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Business_SW_05Nov13.pdf wrote:
The first full backup is performed at the next scheduled occurrence of the backup
depending on the schedule you specify. The next full backup is performed at the
interval you choose calculated from this first backup.
So you have to be careful about when you kick of the backup schedule in order to manage the timing.
Another way to manage this is to use 2 backup jobs - one that always does full backups (once a week), and another that never does full backups (running the other 6 days).
ChevaTomme
Hi, thanks for your reply.
I am running RAIDiator 4.2.26.
Yes, but that "next scheduled occurrence" isn't really true, when i have performed manual test-backups.
I was hoping that editing settings and saving would reset what is considered to be "next scheduled occurrence" so that the next one would perform a full backup.
I might have to look into your suggestion by having separate jobs for Full and Incremental backups.
- ChevaTommeApr 28, 2021Aspirant
Just noticed that it is not possible to create a backup job that never performs a full backup.
It has to make a full backup at least First time then it should hopefully continue and make only incermental backups in eternity.
- StephenBApr 28, 2021Guru - Experienced User
That's true with 4.2.x firmware. OS-6 has a "never" option.
Yes, it will be incremental after that. So you could start doing the incremental backups days 1-6, and then kick off the full weekly backup on day 7 (using the same destination). That would eliminate doing full backups two days in a row.
