fobot
Aug 12, 2018Aspirant
ReadyNAS Ultra 2 plus Corrupt root directory.
Hi
Noticed quite a lot of older posts on migrating from os4 to os6
http://netgear.nas-central.org/wiki/OS6_on_Legacy_x86
All the links are dead now though. I've tried modifying the head...
- Aug 12, 2018
I've sent you a PM with the latest files grabbed from my archive.
If you install the PREP add-on you avoid the need to do a factory reset manually using the boot menu as it will trigger one at the appropriate time after you reboot to install the upgrade to OS6. That's handy especially if the unit is at a remote site and heading over there would be time consuming.
bedlam1
Aug 12, 2018Prodigy
Just follow the guide here, partcularly the update Bios whilst still running 4.2.xx LINK
Read all posts
Do not power off when updating Bios
- fobotAug 12, 2018Aspirant
Amazing , thank you!
