adglab's avatar
adglab
ReadyNAS Ultra 2 shared resources and permissions.
Hi all. Just reading this document from the link below about shared resources and permissions from Active Directory, I'm not quite sure the way to do the same from Server 2019.   Setting up Active...
  • StephenB's avatar
    Sep 15, 2021
    adglab wrote:
    At what os6 version can be updated the RND2000? I saw from 6.0 to 6.10 but I'm not pretty sure what release must be selected.
    The current binaries would install 6.9.5.  If you want to convert to OS-6, you should upgrade the RAM from the stock 1 GB to 2 GB.  Some folks have run into out-of-memory issues with the stock memory.
    The instructions I generally give are
    1. BACKUP, BACKUP, BACKUP
    2. Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
    3. Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
    4. After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
    5. Go through the setup process on the converted NAS
    6. Update the NAS to the current OS 6 if you like(check for updates will work).
    7. Restore files from the backup.
    Note that 6.10.5 has some issues (which need a hotfix to resolve).  If you upgrade to it, then I suggest is to leavomg the admin password set to password until you get the hotfix.  Otherwise you might get a nasty login loop that can be hard to resolve.
ProSupport for Business
