SamirD
May 31, 2020Prodigy
ReadyNAS Ultra 6 and ST8000NM0055 on 4.2.28
Not new to NAS units as I have a Synology and several Intel SS4200-E units, but new to the ReadyNAS. Set up a 1TB drive in 1 after a factory reset, logged into Frontview and saw it was set up cor...
SamirD
May 31, 2020Prodigy
(Couldn't type anything after the table)
After just 10 minutes, the drive was indicating yellow and the status of the drive was now 'dead'. Being that the drive could be doa, I pulled it out and swapped in a 1TB WDC RE-series and after 4hrs the volume is now showing X-RAID2, 2 disks Redundant.
I've run another smart short test on the Exos (did one when I first opened it), and it passed the short test. I'm running a long test now and it should be done in 10 hours.
If the Exos passes the long test, besides removing the 2x 1TB and putting the Exos in and doing a factory reset, any other ideas on getting it to work, or why it was 'failed' by the ReadyNAS? I have SSH enabled so I can run some commands if you need to see dmesg or anything like that. Thank you in advance!
