SamirD
May 31, 2020Prodigy
ReadyNAS Ultra 6 and ST8000NM0055 on 4.2.28
Not new to NAS units as I have a Synology and several Intel SS4200-E units, but new to the ReadyNAS. Set up a 1TB drive in 1 after a factory reset, logged into Frontview and saw it was set up cor...
Sandshark
Jul 10, 2020Sensei
Yes, "high density", 2Rx4 (as opposed to 2Rx8 ot 1Rx8, and often labeled "AMD only"), RAM does not work in the Pro6 or most any Intel system of that generation. Since most desktop PC's of the time were limited to 4GB by their 32-bit operating systems, 4GB 2Rx8 sticks are hard to come by or much higher priced. Servers, which tended to run 64-bit OS's that can use more memory, also tend to use registered and/or ECC RAM, which also will not work on the Pro6.
SamirD
Jul 10, 2020Prodigy
Thank you for the additional details about the ranking and compatibility! That helps a lot. :)
Yep, I have servers so pretty familiar with ranking and banking and the different types, and it's pretty interesting to know that a lot of these peculiarities go all the way back to ddr2 days where fbdimms were the big topic back then.
