Aldorex
Nov 19, 2020Aspirant
ReadyNAS Ultra 6 stuck at "ReadyNAS" logo
Hello I'm new to the forum, and I've just joined to ask for friendly support, so thanks to anyone willing to read my post. I was trying to upgrade locally My ReadyNAS Ultra 6 to the 4.2.31, but ...
Sandshark
Nov 19, 2020Sensei
The NAS is finicky about the USB devices it will accept for a USB recovery. Not being able to use the boot menu points to needing that, though there may also be an issue with the data volume. Try another USB drive, and stick with USB2 only and <8GB, and you may have better luck.
- StephenBNov 20, 2020Guru - Experienced User
Before you try another USB recovery, I suggest removing the disks (labeling them by slot), and powering up the NAS diskless. Normally you'll see a no disks status on the LCD when you do this. If you see this status, the USB recovery might not be needed.
- AldorexNov 21, 2020Aspirant
Thanks for the kind reply!
I don't know why, but I also had to do a Factory Reset before the USB key was recognized.
Again, thanks for your help!
