MikeBob
Sep 21, 2015Aspirant
ReadyNas104 Adding a new hard drive
I originally setup my ReadyNas104 with three 3TB WD Red drives using X-RAID. Everything is working perfectly with that setup. I am now trying to add a new unformatted 2TB WD Red drive. The drive ...
- Sep 21, 2015
XRAID requires the new drive to be the same size or bigger than the existing drives. So it can't add in your 2 TB drive.
You can switch to flexraid, and create a new volume for the 2 TB drives. It won't be protected by RAID, but you can create shares on it.
You can also destroy the current volume and create a new one. You'll lose all the data on the current volume. If you do that, you probably should uninstall all the apps first (and reinstall them when you have a new volume created).
mdgm-ntgr
Sep 21, 2015NETGEAR Employee Retired
With X-RAID the disks you add need to have at least as high capacity as existing disks.
