MikeBob's avatar
MikeBob
ReadyNas104 Adding a new hard drive
I originally setup my ReadyNas104 with three 3TB WD Red drives using X-RAID.  Everything is working perfectly with that setup.   I am now trying to add a new unformatted 2TB WD Red drive.  The drive ...
  • StephenB's avatar
    Sep 21, 2015
    XRAID requires the new drive to be the same size or bigger than the existing drives.  So it can't add in your 2 TB drive.
    You can switch to flexraid, and create a new volume for the 2 TB drives.  It won't be protected by RAID, but you can create shares on it.
    You can also destroy the current volume and create a new one.  You'll lose all the data on the current volume.  If you do that, you probably should uninstall all the apps first (and reinstall them when you have a new volume created).
ProSupport for Business
