Sportradio
Oct 09, 2025Aspirant
ReadyNAS104 no data after hotswap
Hi, I had the Volume: Volume data health changed from Degraded to Dead. I hotswapped the Volume 1 today, with an 8TB drive and now the other 3 drives are showing red, and the new drive is bl...
Sportradio
Oct 11, 2025Aspirant
Thanks Stephen
Can you point me in the right direction for a data recovery service?
Sandshark
Oct 11, 2025Sensei
When StephenB says "don't do that", he means don't delete the volume via the UI, not don't physically remove them. Which are you saying you did? If all you did is remove the wrong drive, then your volume may be recoverable, especially if the NAS didn't even start to sync the new drive. You can get more info from the log .zip file. StephenB is good at helping you decipher the logs.
