basysaz
Dec 11, 2019Tutor
Recovering Admin PW - OS Reinstall doesn't work
My RN312 with two 4TB drives in RAID-1 and running OS 6.9.1 is working OK on my LAN. NAS volumes mount on both Mac (macOS 10.13.6) and Windows 10 Pro (1903) and operate nominally. But I've mispl...
Sandshark
Dec 11, 2019Sensei
Is your OS partition being reported as too full? That can cause a lot of issues. If it's not, a balance and scrub should verify the file system is intact so you can try the re-install again and, perhpas, have better luck.
- Jul 15, 2018Retired_Member
